Carbs fart cough
Carbs fart cough
I know this subject is been discussed before and I have done my searches, but no direct compairison was found.
OK it's 2005 road king custom, 1300 miles, on the bike, I got true dual rinehart and KN high flow intake filter, that is all I know of.
Sympthoms: Bike would be running fine, and after riding for a while, sometimes when I try to come to a stop and I press the clutch the bike cough/ fart and dies. And the weird think it doesn't happen all the time,
Another one is If I'm stopped at a red light idling for a bit as I pull the gas getting ready to take off, same think cough /fart and dies.
Now please note both situation are when bike is warm/hot, the other thing is the condition is intermittent, I could go on for half an hour in traffic stop and go all the abuse, without nothing going wrong, or if the bike is in a bad mood, it would do it constantly for like 5 minutes and all of the sudden like someone fixed the bike it's fine again and I can stop and go without a problem. I couldn't even simulate the condition to the dealer to see the problem, because the bike would be on a good mood when I take it there.
RE: Carbs fart cough
Have you checked for leaks around your intake manifold? With the problem being intermittent, I wouldn't think it is a tuning issue. Your notgiving thethrottle a quick twist when it happens are you? A lot of guys like to do that. If you are I would check the accelerator pump setting. I could be shooting too much gas in when you blip the throttle. I'm just trying to give you things to think about.
ORIGINAL: myglide
Thanks myglide
PS: how do you check/adjust setting on accelerator pump
Spitting out the carb is a sign of a lean condition or timing retarded.....since you have a crank position sensor we can forget the timing so lets look at the carb. Your having your problem at 0% throttle to 2000 rpm (or just off closed throttle) this area is fueled by the pilot jet so install a 46 or a 48 pilot jet....this will richen the mixture up slightly and get rid of that cough/spitting. If it wants to die on you coming to a stop you might set up the rpms a bit with the throttle stop screw on the right side (where the cables connect).
Good Luck
Good Luck
Thanks Doc1, a couple of questions:
Idle screw I read somewhere, that if it was too high it would actually causes it cough, so do I need to turn it up or down?
The pilot jet, is it an easy procedure (medium wrencher) to change? and does it act intirmettingly and only when hot?
thanks
Also I would like to add a little history on the bike that might help, When I bought the bike this last january it had only 788 miles since 05, and it was acting very badly because of old fuel in tank, and I took it ot dealer and they clean carbs, tank and chenged one jet. Just fro the record, maybe they missed cleaning something? anything comes to mind?
thanks
ORIGINAL: Xguy
thanks
thanks
The float bowl has to come off the carb and a small, thin, screw driver is needed to get up inside the pilot jet standoff. I have a special pilot jet screw drive so I won't bugger up the jet when removing or installing it.
As far as your dealers work cleaning the carb....who knows what they did.....one thing I see people miss is the air bleeds but if they where clogged it would make a rich condition not a lean one.
Thanks Doc, no I meant the idle control screw the one to the right of the carb that raise RPM actually, if set high sometime I feel that the carbs farts when I shot it off, and I also read somewhere that it causes back fire, that is why I try to keep it as low as possible , of course with bike idling nicely, and of course I don't have a tach so I go by ear.
I will take it to a wrench and have him change the pilot jet and hope this will cure the problem. will let you know that turns out.
Well after reading the manual, I think it's gonna be easy for me to change the slow jet, opne question though, how do I know what I have so I can go a step higher, it would be stupid to excahnge a 46 with a 46, and I have done that stupid mistake befoer not knowing what the bike had when I bought it, lol I installed a K&N filter only to find out later that I had a screaming eagle in there , so is there a number engraved on the jet or any other indication of the size?
thanks
thanks
