SERT Displacement Setting
Just curious.. Was looking at my SERT MAP and had noticed that the Displacement Setting \\; under the constant settings in the MAP is set to 110.3 \\; \\; When in fact I'm running a high compression 10.5:1 103 CI - \\;
 \\; Does this effect the fuel delivery ? \\; \\; \\; \\; I believe I may be running a bit rich is the reason I ask.  \\; thanks  \\; |
RE: SERT Displacement Setting
Changing the CI number in the constants will effect the VE tables. Your tuner may have bumped up the Cubic Inch number because he was reaching the upper limit of the VE cells he was trying to add to. In effect, the bigger the Cubic Inch setting, the higher the VE tables can be set.
Excellent Information.. Thank you
ditto
Be very Careful with just changing the CI. Your present tune, afr's,  \\;will completely change and you will not know where the burn is unless you get it tuned again. The only reason you really need to worry about the CI is like I said above, you ran out of room for bigger
ve numbers. |
© 2024 MH Sub I, LLC dba Internet Brands
