Results from SE 110
Results from SE 110
Just got my SG back from the dealer. \\; Had them install the 110 Stage 1 Kit. \\; Opted for the 257 cams instead of the 255's. \\; Running the Stage 1 air cleaner, SERT, and Rinehart TD's. \\; All SE parts with no modifications. \\; Ended up with 104 hp and 114 lb/ft. \\; Had a Stage 2 103 big bore before this mod and 110 has lost a little low end over the 103 with the 255 cams, but this is due to the 257 cams. \\; Otherwise above 3 grand it is a rocketship. \\; If I can get computer literate I would post the dyno sheet. \\; Otherwise just email me and I will get it to you. \\;
RE: Results from SE 110
Sorry don't get around computer much. \\; Had the oil pump go out which wrecked my crank. \\; That's what prompted the change. \\; Luckily still under warranty. \\; Out of pocket expenses were $3400. \\; Harley threw in $1300. \\; Would have been cheaper but went with the 257 cams, so \\; I now have an extra set of 255 cams. \\; Any other questions please let me know.
 \\;You will like the 110, I've got 1400 miles on mine now and it runs better all the time. I did the super tuner and D&\\;Ds 2 into 1 and am getting about the same numbers so you got a good tune!
 \\;You are right this engine really comes alive at 3 grand all the way to 6200 rpms.
ORIGINAL: caspr2
 \\;\\\\\\;I'm running the SE heads, I went that way to keep the warrenty.
ORIGINAL: bwoltz
Just curious,
What heads are you guys runnin' on the 110s?
Bruce
Just curious,
Bruce
