EZ Mikuni vs full kit hsr 42mm
Hey if anyone can answer my mikuni questions I'd appreciate it. \\; Posting has been difficult with the forum issues and I couldn't get the questions to post here. \\; Only in the softail area.
Gracias
https://www.hdforums.com/m_3613244/m...tm.htm#3613244
Gracias
RE: EZ Mikuni vs full kit hsr 42mm
EZ kit is fine, as long as you have an aftermarket filter already. That is the biggest difference. I run a Doherty Powerpacc with mine.
Go to Fox Distributing at http://www.mikuni-foxdist.com/order.htm and get the mikuni milage kit and install it. Also get the #20 pilot jet and 22.5 just incase the 17.5 with the kit is too lean. Follow the instructions in the kit, and your scoot will run good. I am running 20 pilot, 165 main 98 needle and a 60 pumper on my 95" motor. The kit originally came with a 17.5 pilot and a 50 pumper. I get 38-40 around town and 42-45 touring two up. This is on an E-Glide.
