Sponsored by: Jekill and Hyde
Slow Ride
Old 12-10-2008, 12:55 PM
wolflover72's Avatar
wolflover72
wolflover72 is offline
Default Slow Ride
Hello, I am new to owning a Harley even though I have wanted one for years but always could only afford metrics. I picked up my bike at what I believe to have been a steal but I am having some problems and wondering if anyone had any ideas. I am mechanically inclined and really do appreciate any help. Here is my symptoms.
I just bought a 98 xl1200c with aprox 14,000 miles. It has a small miss in the rear cylinder but it hasn't been drove much in the last couple of years and then it was only around town. It also doesn't want to get above 75-80 mph. I tried changing the plugs, Harley fuel treatment and cleaned the screaming eagle (k&n I am assuming) air filter. I have ran a couple of tanks of premium through it and tried to ride it like I stole it to "blow out the cobwebs". Any ideas? Thanks from the Rocky Mountains of Colorado.
Doc
Old 12-10-2008, 01:36 PM
hollywood1959's Avatar
hollywood1959
hollywood1959 is offline
Default wires
Change the wires front to back see what happens.
Old 12-10-2008, 02:37 PM
wolflover72
I will give it a try this weekend but with a 2 cylinder if they were backwards it wouldn't even run would it, not to mention the front cylinder would be missing also???????
Just questions, but I will give it a try. Thanks
Old 12-10-2008, 04:48 PM
1931jamesw's Avatar
1931jamesw
1931jamesw is offline
Not neccessarily. Harleys fire almost simultaneously.
Old 12-10-2008, 05:24 PM
Old Gunny's Avatar
Old Gunny
Old Gunny is offline
Also might be the fuel filter. Add to the list
NOW
Please, to have a good experance with your Harleys (note I said Harley'S), buy a Service Manual. Best investment for you.
Old 12-10-2008, 06:28 PM
Base401's Avatar
Base401
Base401 is offline
I had a 90's sportster for quite a while and had the exact same problem with limited max speed. It turned out that attached to the fuel petcock was a little fuel filter screen that was inside the tank and it was clogged up to heck. Pull the Petcock out to clean the little filter. Oh by the way, Drain your tank into a gas can or you get stuck with one finger over the hole and one hand for the petcock. Dosnt work well.
My milage was about the same to 14,000 give or take. Hope that clears it up for you.
Brian
Old 12-14-2008, 01:33 PM
wolflover72
Default Thanks
I wanted to say thank you to all who have welcomed me and all the tech advice. Happy Holidays.
Doc
Old 12-21-2008, 02:33 PM
wolflover72
Things have went from bad to worse. It has been miserable cold here so I haven't done anything to the bike yet but I started it in the garage today and now I don't have any hitting on the rear cylinder. I removed the wire and am getting all kinds of spark (ouch). It runs the same with or without the wire on and the pipe is not heating up at all and the front one is hot. Any help would greatly be appreciated. Thanks. Doc
Old 12-21-2008, 05:46 PM
wolflover72
Please, any help before I go to the dealer would greatly be appreciated.
Old 12-21-2008, 06:02 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
You need 3 thing to start a engine's combustion process , spark , fuel and compression. you've got spark , so while that spark plug is out, thread a compression tester in that hole and check that if it checks out then the issue is from the valves back for example intake manifold gaskets, carb, petcock and fuel. If it is only the rear I would be thinking about a bent valve or it could be a loose push rod if equipped with adjustables. That's just my not very lucid ramblings!
Quick Reply: Slow Ride
