Cams
Old May 12, 2009 | 07:01 PM
Parkerhd36's Avatar
Parkerhd36
Default Cams
I posted this in the Dyna forum too, may belong better here.
Sorry, i know its here somewhere, and have searched, just cant seem to find what im lookin for. Have heard and read somewhere about replacing cams. Im lokoin for information on the pros/cons of it. was orderin parts the other day from the stewaler and mentioned it, ended up orderin some 255's along with v&h pipes, screamin eagle intake and tuner. he basically said cams are a simple swap, easy hp. what am i gettin into here? im really just lookin for more power, and better sound
Old May 12, 2009 | 07:24 PM
dawg's Avatar
dawg
The pipes, A/C and tuner will give you more power. The cams will deepen the sound a bit and will give you even more power. Once you get it all together, get a good dyno tune. Power can be found by having a good head port, but that's another story. I'll think you'll be happy with what you're doing.
Old May 12, 2009 | 09:41 PM
mphamrick's Avatar
mphamrick
That is what I did and I am really happy. I did not do the dyno and I did not do the tuner.
Old May 12, 2009 | 10:47 PM
oct1949's Avatar
oct1949
what bike are U putting the 255's in? its a really good low, low mid, heavy bike cam.
Old May 14, 2009 | 08:35 AM
Kbore's Avatar
Kbore
Originally Posted by Parkerhd36
..... cams are a simple swap, easy hp. what am i gettin into here? im really just lookin for more power, and better sound
Its all easy if you know how. Pros and cons depend on your tool crib, wrenching experence level, what you are weanting to accomplish with the build and wallet thickness You need good tools and torque wrench(s).
Order all tools, all parts; push rods, all gaskets, o-rings, cam spacers, oil and filter, Loc tite, assembly lube etc. Yo might as well install a +8" clutch cable for your apes your gonna install, and an easy pull clutch ramp wile you have access.
Remove exhasut
Drain Oil
Remove Cam cover- chase threads with a tap
Remove pushrod clips
Find top dead center- cut pushrod out- repeat
REmove primary sprockets and chain
Remove cam plate and oil pump
Replace inner cam bearings
REplace cam plate bearings and cams
Replace o'rings, install oil pump on crank
Install cam plate
TOrque cam plate
Align oil pump
Align, measure, shim, install, torque" primary drive train"
Install pushrod cover/ pushrods
Find top dead center- adjust pushrods- repeat
INstall gasket, cam cover, oil, filter
Prime oil pump turning rear wheel and listen for loud noises
Install exhaust.
Download new fuel map.
DO WHatever I left out
Check your list again for steps you left out
and your parts table for parts you left out
Cross fingers- hit starter- watch for ol pressure.
Ride
Old May 14, 2009 | 11:43 AM
paul s's Avatar
paul s
"Yo might as well install a +8" clutch cable for your apes your gonna install, and an easy pull clutch ramp wile you have access." Hey,Hey, not all of us Dyna riders roll with apes.
Old May 14, 2009 | 11:53 AM
paul s's Avatar
paul s
I don't need the easy pull clutch either because I have this.
Old May 15, 2009 | 10:45 PM
oct1949's Avatar
oct1949
DUDE the clutch is on the left side, use the other hand!!!ha..
Old May 17, 2009 | 11:04 PM
Kbore's Avatar
Kbore
Ha. BUSTED!
Old May 18, 2009 | 09:56 PM
Bad Disposition's Avatar
Bad Disposition
Default Cams
KBore,
TOOoooooooooooooooooo funny!
parttime379
Feb 24, 2020 09:27 PM
N Z Hardcore
Dec 11, 2017 10:00 PM
13Dyna103
Aug 26, 2014 09:10 PM
Screenz
Jul 12, 2013 06:47 PM
Manish_Hawg
May 30, 2012 10:02 AM
