How to remove Evo inner cam bearing - Harley Davidson Forums
P
Thread Tools Search this Thread
Old 10-20-2009, 12:40 AM
Z's Avatar
Z Z is offline
Default How to remove Evo inner cam bearing
Thought I'd post a few pics showing the removal of an inner cam bearing for a 98 Big Twin Evo.
1. The subject of my attention: An existing Torrington bearing (as seen through a lifter block hole) that I want to replace because I'm installing a new VThunder 3020 cam (failed lifter took out my previous 3020).
2. FYI: Here's how to tell a Torrington bearing from an INA (more precisely, how to tell a "full compliment" bearing--the Torrington in this picture--from a "caged" bearing, like the INA one shown.) Not sure who I pilfered this pic from, but I think I got it from elsewhere on this board. Note: There are some bearings being sold as Torringtons that bear the letters "TORR" stamped on them. I contacted Timken and the Process Line Manager in charge said current standards call for their bearings to be stamped "Torrington". He's not sure if these "TORR" bearings are fakes or perhaps some old product that pre-dates the current marking standards.
3. "OEM Blind Hole Puller Set" rented borrowed from AutoZone ($175 fully refunded deposit)
4. Slip this into the bearing with the lip behind it, and tighten the bolt to expand the puller lips behind the bearing.
5. Attach the slide hammer and give it a few good jolts, and the bearing pops out nicely.
6. I used the same tool to remove the gear cover bushing. Note: Do not remove this bushing unless it's necessary. Per the service manual, replacing this bushing requires that you: 1. press it in, 2. drill a very precise hole through it and into the gearcase cover, 3. pin the bushing in place, 4. drill and chamfer a hole through it for an oil passageway, and 5. align ream it to properly fit your camshaft and to align it with the inner cam bearing. I yanked mine before I realized all this, and took the cover to a local indy who charged me $60 to press-in the bushing and oil seal, and ream, drill and chamfer the bushing. The bushing fit tightly enough that he felt it wasn't necessary to pin it.
7. ...and the bearing oil seal.
Old 10-20-2009, 02:48 AM
jtmurph00's Avatar
jtmurph00 jtmurph00 is offline
Damn nice.
Planning on attempting this myself in the next few months those pictures are a helluva lot better than the manual.
Old 10-21-2009, 06:10 PM
Z's Avatar
Z Z is offline
JT, glad you found it useful. I get so much value from this forum and others like it (for all my vehicles) that I always try to give back when I do a major repair by writing it up with pictures, because I know how much I appreciate pics from others. Just payin' it back and payin' it forward.
Old 10-23-2009, 09:26 PM
jhnmflr's Avatar
jhnmflr jhnmflr is offline
great post . Just did cam etc myself and was looking for the correct tool instaed of a regular puller . I had to actually show the guys at autozone what tool I as looking for but they had it . Thanx!
P
Thread Thread Starter Forum Replies Last Post
2008 flstsb cross bones crossbones trike Scott Hall Hacked, Conversions and Trailering 42 11-14-2016 05:50 PM
Free Mod, air filter cover WS6 Formula Dyna Glide Models 30 06-28-2011 02:09 PM
New inner cam bearing is labeled "Torr" not "Torrington". Is this normal? Z Exhaust System Topics 9 10-22-2009 06:10 PM
Main Drive Gear O-Ring? Z Primary/Transmission/Driveline/Clutch 4 10-28-2008 12:32 PM
FS: Denver's Springer/Dual 48mm Webers lameophucnuckle Motorcycle Parts For Sale-Misc. Parts 0 08-08-2008 03:25 PM
Tags
bearing, bearings, cam, camshaft, evo, harley, install, installing, lifter, picture, puller, remover, removing, shovelhead, torrington
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Featured Sponsors
Vendor Directory
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
