Cams for a TC88
Cams for a TC88
Ok heres the deal. I want to keep my motor at 88 inches and try to get 90hp out of it. I dont know why I want to do it this way but for some reason I do. Well I have decided to change out my cams and I was thinking about S&S 510g's or Andrews 37's. Im sure there are pros and cons to each choice but keeping with an 88inch motor which one would give me more mid to upper rpm power? Also does anyone have any dyno sheets of an 88 inch motor with either of these cams installed?
Chris
Chris
RE: Cams for a TC88
I'm sure you may already know this, but as much as cams might add some power they will just change where the power you do have is delivered. I talked to a harley parts salesman the other day and if knowledge varies inversely with tooth loss he was a HD genius. Anyway, I asked him about switching cams and staying at 88 inches for now. He said not enough of a difference and to wait until I was ready for some more cu. inches
RE: Cams for a TC88
Chris....
It is possible to achieve your goal.
THe key is gonna be getting the compression ratio to the "sweet-spot" for the cams. I would not suggest exceeding 9.5:1 with the 37's or 9.7:1 with the 510's. If you do, you will be risking pinging.
If you could get your heads cleaned up (port/polish) and CR set to match the the cams, once properly tuned you'll have nice numbers. One other thing that might help would be a good 2 into 1 pipe (D&D, SuperTrapp, Bassani).
Let us know how it works out!
RE: Cams for a TC88
Here is a link to Head Quarter's website. Their HQ-0034G cams are what I'm looking at when I do this same exact thing after my warranty runs out.
Check out this quote from their website -
" John’s Performance in Washington state gets 92.4 HP and 96.4 foot pounds of torque from a stock 88 cubic inch 2006 Street Glide using a Head Quarters HQ-0034 bolt in cam, Power Commander and Rhinehart Tru-Duals."
http://www.head-quarters.com/index.html
Kuryakyn Wild Thing TC-1G cams are another to think about. They seem to be making some very good numbers in a 88" motor.
Steve
Steve
RE: Cams for a TC88
I was at the open house for JP Cycles a few weeks back and watched the dyno drags. There were two bikes that kurakyn had some bolt ons added. They were both newer super glides. The one had bolt in cams mentioned above and the power they made was incredible. Dont recall the exact numbers but the bike ran just over 9.5 quarter mile time.
I was impressed and it sounded awesome.
RE: Cams for a TC88
I have a set of 510G's in my 05 Ultra with 88 cubes, no headwork, SEII slip ons SE air cleaner and DFO, These cams pull very well but I have not had it on a dyno. I would reccomend these cams to anyone, power comes on strong at about 2800 to 3000 rpm and they work very well at cruising speeds also. I'm sure with a better tuner than the dfo I could get more out of it and will probably do so in the future.
RE: Cams for a TC88
ORIGINAL: but Ill try 2 try
martin10
Engine Mechanical Topics
14
05-24-2016 07:08 PM
