I have 150 PSI in each cylinder. Can I use 87 gas?
99 Ultra, 95" Screaming Eagle upgrade, 203 cams, CNC machined heads, flat pistons. Do I have 9:1 compression ratio or...?
You can damn near use kerosene! Only kidding!
At that compression I'd say that 87 octane would be absoluetly fine.:icon_beerchug: Scott |
Originally Posted by Hillsidecycle.com
(Post 5943502)
Bud of mine has a 02 SE 95'' and he runs 87 all the time without issues. Mind you , I don't know what cam it has and sometimes this could have a play on what works too. Basically if it pings, then no.
Ron |
Ran 87 octane in my bike with 205ccp this summer....ran fine and didnt even ping...suprizingly. That said i usually run 93 here as many places have it.
One atmosphere is about 15 lbs per sq inch. This number varies with altitude and temperature.
The way I figure this, and I may not be completely right, is whatever number you get, less 15, divided by 15. Round about. so you do have about 9-1 compression. |
An interesting side note.
Where I worked awhile back we had a BIG old air compressor that was single stroke for some reason. Used for a particular job. Most this size are two or three stage with intercoolers but this one wasn't. It pumped 115 discharge. Or about 6.5-7 compression ratio. The temperture before the cooler was 450 Degrees. Always though about that. So if you have 10-1 might be 650-750 degrees before the spark. Don't need much |
© 2024 MH Sub I, LLC dba Internet Brands
