Cylinder Head Bolt Torque
I'm putting the heads on my 95 build now, I have the .030 metal gaskets, should I use the same torque as my HD manual says or should I use another method?
options
The manual method works fine. I don't use it. I final torque to 42 ft. lbs..
same here,i go 10-20-30-42,in the same pattern as the manual
Originally Posted by prodrag1320
(Post 6149760)
Yup, like said above, same method i use. Use a few drops of oil under the head and on the threads to get an accurate tq reading.
© 2024 MH Sub I, LLC dba Internet Brands
