Please define "stage 1,stage 2,stage 3...etc...
The stages, or levels of that here, refer to our cylinder head modifications. Stage I, being basic head work, and Stage IV, is an OEM casting that will support a 124", without any problem.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Stage 1 = air cleaner, exhaust, and fuel adjustment
Stage 2 = stage 1 + cams
Stage 3 = stage 2 + heads
Big Bore doesn't count as a stage, and neither does a blower, turbo, or anything else.
The Moco offers a stage 4 package............still trying to figure out what that really is that makes it a stage 4.
Steve
Steve
Steve
Steve
My interpretation of a Stage 1 is it involves undoing some the noise and environmental restrictions imposed on Harleys (and all other vehicles). On my bikes I fitted a SE air filter, to replace the quiet stock airbox, fitted after-market mufflers to derestrict the exhaust a little, and (with carbs) rejetted them to give the motor better air/fuel ratio. On a EFI bike that requires adjusting the electronics. I would also include lowering overall gearing, as that is the easiest way to wake up a Harley, as the gearing is artificially raised to reduce engine speed at noise metering road speeds.
Stage 2 includes changing cams, in other words opening up the engine to change internal parts and Stage 3 is making more serious changes and substantially tuning the thing.
Added later: Several of us obviously wrote our replies at the same time!
all good info.
if i understand it correctly,the "stage blah,blah..." probably started as a way for salesmen or service guys to relay to their customers the various upgade options available to them.over time,other companies have adopted this basic description and use it as their own marketing descriptions,right?
thanks.
leftcoast carl
P.S.- based on this info,i'm currently paying for a stage 2.bigbore to 95",cams,true duals,racetuner,air breather and hydraulic cam.
thanks.
leftcoast carl
all good info.
thanks.
leftcoast carl
thanks.
leftcoast carl
anubisss
07-01-2009 01:01 PM
