SE259e Cams
With the 259E's, you will need a bump in compression to make this cam work the best and you will need high lift springs in your heads, unless the newer twin cam stock heads can support a .579 lift.
You won't need any of this with the 204's. The 204 is a good bolt in cam. You will be happy with the TQ & HP gains. If you have the time take a look at the HQ-TC-500 cam from Head quarters too.
This what we like to run>>>>>> on stock 96 inch motor.
FUELING 525 BOLT IN CAM
TMAN 555 BOLT IN CAM
FUELING 574 BOLT IN CAM
Was going to do the 259 till I looked at the valve timing.
This is a epa cam.
If I had to chose between the 204 and the 259 I would take the 204. Hearing good things on the 204 but the 259 people were expecting more. This may be due to compression but like I said I dont like the timing for some reason on paper it reminds me of the 255. If you were to draw this cam on paper with the specs on a graph.
This is a epa cam.
In a Dyna 96" w/Stage one, would you do the F-525 or F-574? I want an all-around cam, I'm rev-happy but want to get up and go quickly, too. I think I'm in the 2-4RPM range often, but I've been known to hit the limiter from time to time and I know the stock cames give up past 4,500/5,000RPM right quick on my bike. In my Stage 1 when I had the quiet baffles in my bub jug huggers, I could spin the tire off the line with the right clutch movement... the BUB 2:1 I had was garbage... took away torque... but sounded like sex. The good kind...
