88" vs 95" HP
88" vs 95" HP
I'm thinking about doing the 95" SE2 big bore kit with the 203 cams to my 88" 2004 E-Glide, I have been searching for what the actual HP and torque gain will be and the more I search the more confusing it gets. It looks like the stock 88" is about 72 HP and 75 lbs of torque what will these numbers be with the 95" SE2 kit ( jugs ,pistons, cams and remap ) I've talked to several guys that have done this and they say the power gain is big, what do you guys think ? ? ?
THANKS ! ! !
THANKS ! ! !
THANKS ! ! !
THANKS ! ! !
Bore to 98"
Andrews 37 cams set at 9.9 cr.
Our Stage II Heads
D&D Fatcat.
Doc's Performance Tuning, in Mineola, Fla just tuned one of these reliable combo's that rolled 106/111.
Torque almost flatlines.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I'm thinking about doing the 95" SE2 big bore kit with the 203 cams to my 88" 2004 E-Glide, I have been searching for what the actual HP and torque gain will be and the more I search the more confusing it gets. It looks like the stock 88" is about 72 HP and 75 lbs of torque what will these numbers be with the 95" SE2 kit ( jugs ,pistons, cams and remap ) I've talked to several guys that have done this and they say the power gain is big, what do you guys think ? ? ? THANKS ! ! !
A cheaper and better way, IMHO, would be to have your OEM cylinders bored to fit a set of SE cast flat top pistons, a set of Andrews TW26 cams, and same associated hardware named above, including street port job.
In either case, you will need a good exhaust like your head pipes with Cycle Shack or Rush slipons, tuner, change cam chain tensioner shoes, upgrade inner cam bearings and a good tune.
If budget will allow, consider upgrading the cam drive system from the spring loaded tensioners to the "hybrid" system with billet plate, hydraulic tensioners and upgraded oil pump.
i noticed you live in modesto if you go to Big Boy Performance talk to scotty and tell him that Jake sent you hell hook you up and they do great work there if you interested
A big part of going with the HD SE2 kit is due to the fact that I am in northern Mn. and we don't have access to dynos and super tuners so I would like to stay with a somewhat proven system. I know that there are a thousand combinations that will output more HP than this kit but for me it is important that it works when it is done. Everybody that I talk to suggests different cams, heads, pipes or something so it gets really confusing. Also is there a fuel management system that I can install that will eliminate the need to have a dealer re-map the the bike ? ? ? I'm not trying to build a crotch rocket but I might convert this to a trike which will need the extra power.
THANKS AGAIN GUYS
THANKS AGAIN GUYS
