have i set pushrods correct
hey guys
i am in the middle of installing 1. woods lifters 2. se pushrods part # 17997 (24 tpi i think) can anyone confirm they are 24 tpi per woods instructions going for .130 total travel turned 3 turns and 1 flat divided .130- by 24 teeth to get turns, just iant sure on thread pitch, it does not say anywhere in the paper work with the pushrods \ thanks |
You can always check with feeler gages the difference from the adjustment nut bottomed out = 0 turn it measure until you get to exactly what you need no need to rely on thread pitch.
S.E. pushrods are 5/16-24. One full turn is .041. Three is .123. One flat .007. Total .130. I've never used Woods lifters, I set the Harley lifters are set at 2 1/2 turns.
thanks
i set them at .130 and unfortunatly i still have the top end noise, maybe a little less but the good news is i got through the lifter change with no problems thanks |
© 2024 MH Sub I, LLC dba Internet Brands
