advice on 103 stage 4 cams
Realized I was probably hijacking someone else's thread in the Dyna Forum (apologies) so decided to start this separately, and this seemed like the right thread.
First disclaimer/alibi: newb. 'nuf said?
I have a SE 103 Stage IV kit installed in my '10 Fat Bob. It's the stock kit from the SE '11 catalog (part# 27516-08B, parts breakout below), including the SE260 cams. Numbers are 104tq/109hp (dyno sheet). Those numbers seem in line with what the catalog projected, but seem low compared to what I'm seeing/hearing on here in some of the other threads. More important to me, as far as the ride goes, the power seems to come in late. I can start to feel it around 2800, and definitely feel it at 3500, although I was really hoping to feel it earlier in the ride (low-mid 2K?). Honestly, it feels kind of sluggish in the low end.
I believe the bike is tuned correctly - again, it's in line with what the advertised HD numbers are for that build, so I'm thinking that I chose the wrong set up for how I want to ride. Given that, it's been suggested that I try a Woods TW8-6 with my current set up.
Does anyone have a dyno of a 103 Stage IV with a TW8-6, or does anyone have personal experience with a setup similar to mine? Can anyone comment on how that cam runs? Any other cam options for my build (again, SE 103 Stage IV kit straight out of the HD SE catalog) that won't require a lot of additional work? I'm not a mechanic, so this isn't something I'll be doing myself, and I'm at my limit for putting dollars into it.
I'm looking to feel that pull earlier in the RPMs, and maybe have it last a little longer - the SE 260 just doesn't give me what I'm looking for.
I've already put money into it, and I would like to avoid putting a lot more $ into it (I'm willing to put a little more to get what I want). I'm hoping that changing out the cam will put it in the arena for what I want.
Info from SE catalog on their 103 Stage IV kit:
Screamin’ Eagle® Performance 110+ Heads - 2.120" diameter intake valves (has ACR)
high-compression forged aluminum 10.5:1 pistons matched to the 110+ heads
SE260 cam
Perfect-Fit Pushrods
58mm EFI throttle body
3-7/8" diameter highlighted cylinders
Super Tuner
SD Heavy Breather A/I (not part of kit)
Bassani Road Rage 2->1 Exhaust (not part of kit)
Appreciate any/all comments, advice, feedback and tips!
Dano
SE260 cam
Super Tuner
Dano
I have heard of the 400 Wood used with a reported 120 on this forum, I have heard the T-Man 625 being used on this forum(around 110?), I am using the DME 575L in mine. I had the SE 251's in my Stage IV and thought they came on a little late. I don't have a whole lot of faith in Dyno numbers being used as a comparison to other bikes, there are to many variables involved. I like my cams and my bike gets good mileage 43-47mpg, runs damn good and most important is fun as hell to ride.
Yeah itll be a couple weeks before the dyno numbers are in. Finshing up some odds and ends on it right now, getting an initial tune on it. then its a nice and easy 500mi or so break in, so id say in probably 2 weeks ill have some numbers.i should be able to get her back in and set up by then. Sorry that probably dosent help you. But once it is completely done ill be posting a full build up with numbers and dyno sheet.
Greybeard...unfortunately you were probably looking for something along the Stage 2 kit. You're going to need new pushrods and more than likely valve springs when you change camshafts to something that will put power in the lower rpm's. Essentially, you'll have about the same amount of labor in the fix as you did doing the Stage 4. My recommendation is to try running in a lower gear than normal in town to keep the rpm's up and downshift to pass. You've got a fun engine upgrade, but it is definitely not made to run at lower rpm's.
I may end up doing nothing more to it - but I wanted to get the opinion(s) of folks more experienced than myself to make a more informed decision if I decided to do so. Thanks for the feedback!
SE260 cam
Super Tuner
Dano
SE260 cam
Super Tuner
Dano
Hit hard off the bottom, and with the cylinder head air flow of that 110" head(approx 158-160 cfm @ .600 lift) it'll pull till 5500 plus.
Just did this same job for a client in the Toronto metro area recently, except he had flat-top pistons, Rinehart duals, 50mm S/E t/body.
Headwork, and Wood 555's, and tuned correctly had him smileing, after he had been to 3 other outfits to correct it.
It was a very sluggish combo, but final dyno reports were 107/115, SAE, with it hitting very early in the rpm band.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
