Which motor
Which motor
Okay guys I'm trying to decide which motor to build. I want it reliable as I tour alot on my bike.
Option 1 screaming eagle stage 4 103 but switching the cams with s and s gear drive 625 or 640's I'm gonna keep the compression at 10.5
Option 2 screaming eagle 113 again changing the cams to s and s gear drive.
What's yalls thoughts on both motors? I have a 2009 streetglide that the motor will be going into and I tour alot on it mostly solo with little luggage.
I am trading my 91 mustang 5.0 for the parts and labor to my best friend as he is the service manager at the local hd dealership. He has the 113 kit with s and s gear drive 640 in his bike and made 124 hp
If I were to do another build I would stick with the 107. No case boring. T-man would be my choice with the thumper series (stage 4) heads. You will get better results than a SE 113 with this build. Do the bottom end as well and you will have a great reliable build. Good luck on teh build whatever you do.
This what I suggest;
Wood 777 cams
Heads re-worked(our Stage III Touring Heads would work VERY well indeed)
D&D Fatcat, our equivilant
Re-work t/body.
Won't make 124 hp, BUT, I guarantee, it'll be one hellava lot more fun to ride, in that touring environment.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
If your bike is an 09, there is no need to go to the gear drive cams, in fact I would tell you not to do it as the late model tensioner setup is fine. If you truly want touring bike power, go with the 113, and rethink the cam choice to something that will give you a bit more torque lower in the RPM band. If sticking with HD parts, you might want to consider the 259 cam. good power where you will use it most.
