S&S 106 stroker question
Thanks for reading everyone!
My 2006 FLHRCI has am SE 95" Big Bore kit with 203 cams and .030 gasket. 15k miles on it, runs well but I want some more.
I'm seriously considering upgrading to the 106" flywheel from S&S including 585 easystart cams (probably going to gear if I change the flywheel), rods, rockers and springs. All S&S in the hope that they work well together. I'll get the stock heads lightly worked over here, nothing major. Also debating whether to stick with .030 gasket or move to .040, I would like to avoid compression release valves.
My question is, any harm in keeping the existing SE pistons and cylinders? They are flat tops as I believe are the S&S that would be sold in the stroker kit.
Can anyone help?
Thanks
Can anyone help?
Thanks
Thanks Prodrag, I know I am about to ask you a stupid question but can I just stick new pistons and rings in my used SE cylinders or do I need to get them worked before I do that.
In my simple mind the new rings should take care of the fact that the cylinders are used but an opinion from someone that knows more than I do would be very useful!
Thanks, that makes a lot of sense.
Next question is, with the 585 do I actually need stronger springs, roller rockers and gear cams?
S&S says that these cams are a direct bolt-it on 2006 TC88 and can run the stock springs but perhaps this is not true when running a 106" with higher compression than stock.
My engine is relatively fresh with only less than 20k miles on the clock.
I'd just like to know if it's necessary before I pull the trigger and then even if technically is not I might still decide to do it to "future proof" the engine so to speak.
Thanks everyone!
Thanks everyone!
Next question is, with the 585 do I actually need stronger springs, roller rockers and gear cams? S&S says that these cams are a direct bolt-it on 2006 TC88 and can run the stock springs but perhaps this is not true when running a 106" with higher compression than stock. My engine is relatively fresh with only less than 20k miles on the clock.
Thanks everyone!
Thanks everyone!
