S&S 509 cams
Looking for a low end torque cam. Has any one had any dealings with the S&S 509?
Thanks Jeff |
Here is more information on the cam.
509: Designed as a bolt-in, high torque cam for 1999-'06 models. 180 psi cranking compression, no need for compression releases. For 88 CID engines with stock compression ratio. Idle-4500 rpm. Valve Timing (open/close)Valve DurationValve LiftCenterlineLift @ TDCIntakeExhaustIntakeExhaustIntakeExhaustIntakeEx haustOpen BTDC/Close ABDC Open BBDC/Close ATDC 509 18˚/18˚46˚/11˚216˚237˚.509"90˚107.5˚.174".140" |
We have been using the 510 and S&S has been pushing for us to try the newer 509 but we have yet to use it.
Originally Posted by Skip's Speed & Custom Cycles
(Post 10761792)
Thanks Jeff |
Thought I would bump this to see if any one has any experience with the S&S 509 cam. According to S&S listing it says it is good from idle to 45K rpm and I want my torque to come on as low in the RPM range as possible.
Thanks Jeff |
© 2024 MH Sub I, LLC dba Internet Brands
