Can't Delete Post
Hubby made a double post in this thread
https://www.hdforums.com/forum/dyna-...-counting.html I combined his and mine together but now I can't delete his thread. What am I doing wrong?? |
Originally Posted by crazyanimal
(Post 8179611)
https://www.hdforums.com/forum/dyna-...-counting.html I combined his and mine together but now I can't delete his thread. What am I doing wrong?? Can I edit or delete my posts? If you have registered and are logged in, you may be able to edit and delete your posts (although the administrator may have turned off this option). Your ability to edit your posts may be time-limited, depending on how the administrator has set up the forum. To edit or delete your posts, click the Edit http://images.ibsrv.net/ibsrv/res/sr...ttons/edit.gif button by the particular post. If your post was the first in the thread, then deleting it may remove the entire thread. Once you've made your modifications, a note may appear to inform other users that you have edited your post. If the edit time and date appear as a link you can click on this to see the differences between the original and edited versions, or between edits if there have been multiple edits. |
Only a moderator can delete posts.. you can edit them down to almost nothing, but the entry will still be there.
click "edit" then replace everything with the word "deleted". That's the best you can do.
thanks everyone.
| All times are GMT -5. The time now is 03:45 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
