Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Softail Deluxe Brake Issue
Old 05-27-2017, 02:28 PM
Buckshot71's Avatar
Buckshot71
Buckshot71 is offline
Stage I
Default Softail Deluxe Brake Issue
Hi, new to site, Have brake issue with my bike. 2015 Deluxe, 1-1/2 yrs old. 10400 miles. Lost rear brake with no leaks or any known issue. Pedal goes to floor board and will not build pressure. Took to dealership and was told the caliper locked up and also caused uneven brake pad wear. Was told that dirt caused the caliper to lock up which caused the pads to wear uneven. New pads and a fluid flush of the system was recommended. Was told that this was not covered by warranty because this fell under routine maintenance. ANY ADVICE, thanks!
Old 04-05-2019, 12:24 AM
Harris Bhutto's Avatar
Harris Bhutto
Harris Bhutto is offline
Stage III
i am facing the same with the same 2015 model. flushed (bleed) the rear brakes thrice but its still the same. What next?
Old 10-16-2020, 11:32 PM
JasonVenice's Avatar
JasonVenice
JasonVenice is offline
Stage I
If you have ABS Brakes you probably need to bleed your ABS unit electronically. meaning, unless you have the computer you would have to take it to the dealer
jokr
08-11-2012 08:40 PM
Billyjax
08-23-2010 11:46 AM
pandol34
05-03-2009 10:34 AM
whylee
04-06-2008 08:57 PM
stone_rider420
01-30-2008 06:23 PM
Quick Reply: Softail Deluxe Brake Issue
