Shocks aren't pumping up
10-27-2017, 05:12 PM
So im reading my manual on shock pressure for 2-up riding. So i want to bump up my pressure. Problem is my shocks are holding pressure at 22 psi. I pump them with the air pump but its not seaming to get above 24 psi. Anybody else have this problem?
10-29-2017, 04:24 PM
10-29-2017, 04:40 PM
I have to actually take the valve out of the bracket it's mounted on in order for the pump to screw on far enough to get air on it...otherwise I couldn't get any air in it at all...nor sure if that's what you have going on or not but you never know
10-29-2017, 11:26 PM
Hmmm that's something I may try next. Thanks for that...
10-30-2017, 09:11 AM
Are you using a standard type shock air pump like the one from Progressive suspension (GP3-60)? These air pumps have a one-way check valve that prevents pressure loss when the pump is removed.
10-30-2017, 07:47 PM
Can you try your pump on another bike, and another pump on your bike?
08ClassicRider
Air Suspensions
01-19-2021 07:39 AM
5x40
15
09-08-2015 08:13 AM
30glock
2014-2023 Touring Models
07-06-2015 06:35 AM
PDDGM
04-01-2012 04:05 PM
OCCoastie
04-04-2011 08:19 AM
