Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Are these Lyndall rear brake pads installed?
Old 08-13-2018, 09:41 PM
Major Slaughter's Avatar
Major Slaughter
Major Slaughter is offline
Default Are these Lyndall rear brake pads installed?
I bought
Lyndall Brakes Z-Plus Brake Pads Rear 7157-Z+ Lyndall Brakes Z-Plus Brake Pads Rear 7157-Z+
from J & P Cycles and paid a shop to install them. Not sure if they did, these look like OEM that are still on there? "Hayes"
is imprinted on these
Old 08-14-2018, 08:56 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,235 Likes on 1,811 Posts
I would Not have used that Link for your example ... WRONG Picture (which can be normal), but CORRECT part# for your 99-earlier Rear Caliper (can lead to a bunch of crappy responses )
"Hayes" as in original name "Kelsey-Hayes" (it looks like they may have renamed to just Hayes) was the original caliper manufacturer.
To answer your question, I personally would call Lyndall to to check if they happen to use Hayes Backing Plates to apply their friction material to
(which would seem odd and doesn't really make sense, but )
In Person, how's the Friction Material look (and actually whole pad) ...New?
Personally, I've never held a Lyndall Pad, so I can't Draw on that. So...
Not being there, I would lean towards NOT being Lyndall, but I would investigate first
Major Slaughter (08-14-2018)
Old 08-15-2018, 09:40 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
I don't believe that Lyndall make their own parts, so it is just possible that they purchase from Hayes.
Major Slaughter (08-16-2018)
Old 08-15-2018, 10:36 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
Here's how you can tell if they're Lyndall Z Plus pads. Hose down the rear caliper with water from a garden hose, thoroughly. Start the bike, head down the nearest open road, wind it up to 60mph and step on the rear brake. If the first thought in your mind is "Oh sh*t my brakes went out!", they're Lyndall Z Plus pads. I think there's a video of a guy on a Sportster using the Lyndall Z Pus Foot pads around here somewhere
Now, humor aside, to be sure you're gonna have to remove them and look. That's really the only way. Sir G is right, Lyndall doesn't make brake pads, they use suppliers and re-brand them.
The following 2 users liked this post by Campy Roadie:
grbrown (08-15-2018), Major Slaughter (08-16-2018)
Old 08-16-2018, 11:12 PM
Major Slaughter
I sent the pics to Lyndall and received a response. The Hayes pads are OEM pads and they recommended I find a new mechanic!
Old 08-16-2018, 11:29 PM
multihdrdr's Avatar
multihdrdr
Hmm ... what did I tell ya
It really would have made No sense for Lyndall to use the Hayes backing plates for several reasons
But a Major Reason is... Why on Earth would Lyndall want someone else's name on their Brake Pads?
Thanks for the Update
Here's your 7157-Z Pads ... See any "Hayes" on there ... No
Old 08-17-2018, 08:45 AM
Rt13MFer's Avatar
Rt13MFer
Rt13MFer is offline
Received 1,594 Likes on 642 Posts
So what your saying is you paid a shop to install the pads that you supplied and they put something else on, or maybe didnt change out your pads at all? You should post the name of that shop right here. Theres NO excuse for a rip off and they should be called out as such.
murrdogg88
06-24-2017 11:50 AM
All Aces
05-21-2017 08:29 AM
cochon
03-17-2016 06:06 PM
Rollbar
02-03-2015 07:29 PM
Casper
11-05-2010 05:54 PM
Quick Reply: Are these Lyndall rear brake pads installed?
