Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Fork Oil SAE 2004 FXD
Old 01-14-2019, 07:59 AM
IanIW's Avatar
IanIW
IanIW is offline
Stage I
Default Fork Oil SAE 2004 FXD
What SAE fork oil would you suggest for a 2004 FXD with Progressive Springs?
Old 01-14-2019, 08:07 AM
HKMark23's Avatar
HKMark23
HKMark23 is offline
Received 1,934 Likes on 1,111 Posts
I'd strongly suggest the drop in installation of a pair of Ricor Intiminators and 5 wt oil. Magic !
Old 01-14-2019, 09:13 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Exclamation
Somewhere around HDF you will find a table comparing umpteen brands of fork oil, their stated SAE and the correctly measured actual SAE. The two are rarely the same! If you go away from the H-D recommended oil, then select a well-known brand and stay with it, don't swap between brands as they cannot be trusted to be consistent. You may have to buy a bottle and try it, then swap for an alternative SAE to get the ride you prefer.
I also have used Intiminators on my Glide and liked them, but have moved on to Ohlins since.
Am4wag
09-15-2014 02:43 PM
barcoeng
Oil Archive (no new posts)
01-11-2014 09:45 AM
iceman0084
07-19-2010 07:22 AM
Naz_Man
03-08-2009 11:40 AM
zoood
11-25-2008 05:11 AM
Quick Reply: Fork Oil SAE 2004 FXD
