Fork seal driver tool
What I have used for years,even back to my dirt bike day's is a piece of hard vacuum cleaner tube that I cut just a little less in half. I'm sure someone will discourage this method, however I have done hundreds of fork seals and luckily haven't damaged one yet. Hope this works out for you.
"Still here"
"Still here"
I've used a socket that's just a bit smaller than the seal od and fits in the fork tube. Turn the socket over so the flat top is against the seal. Put an 8" extension into the square hole in the socket and use a brass hammer to drive it home. The brass won't bugger up the end of the 8" extension.
Received 47,744 Likes
