Whine noise from front in curves
07 FXDB...abt 10000 miles...stock tires shocks etc....been noticing a whine in the front end when I am in a curve...started a while back and seems to be getting louder...sounds just like a low tire but only hear it in a turn...tire isnt low...any ideas?...tia
RE: Whine noise from front in curves
G'day,
My 06 dyna , (stock tires), has the whine, I noticed that the front tire was badly schamfered / worn high ,low. The back tire was a little uneven also. The noise was driving me crazy, only in corners as you said. I replaced the rear tire at about 10,000 and the noise was a little less, the front is due in a few months, so i will have to wait till then to find out the truth. What bothers me is that i don't know why the tire was so damaged when, (nowday), i ride gently and check pressure regularly. I did notice that the rear wheel aligment was way out from the factory, but i'm not sure if that would cause front tire wear ??. I'm not rich enough to through away half worn tires , so i'll P.M. you, ( if you like), when i get the definitive answer. Strangely I have never read any other post on this........anyone else????
Graham.
Graham.
I replaced both front & rear D402's and I have a strange whine now too. But I honestly didn't connect the sound with the tires. Is your whine a steady pitch? My whine modulates... sorts whoop..whoop..whoop.
