changing front brake pads??
RE: changing front brake pads??
Yea. 15K+/- miles is about normal. The pads can be changed without removing the caliper but it's just as easy to remove it to do the replacement. Before removing the caliper, remove the cover from the front master cylinder. Using a wide blade screw driver, gently pry between the brake pads and rotor on both sides to push the pads and pistons back.
Tip: if you don't have it, get the "Fix My Hog" DVD (Sportster Edition). It's well worth the $45 and walks you through most of all the service procedures. www.fixmyhog.com
Hey, wait a second. There is no reason to open the master cylinder. The fluid in the caliper will go back to the master cylinder when you push the pistons back in. If you open the master cylinder and push the pistons back in the calipers, you risk splashing brake fluid on your paint. Not sure about a Sporty but on the other HD's the pads are different(inside / outside) so make sure you take note of it.Make sure that you break the two small bolts loose first before removing the caliper. (just easier while still on the bike). After you remove the caliper, spray it with brake-kleen before you do anything else and then use your old pads to push against toretract the pistons. Also, you'll need to push the pads toward the smallretaining bolts to remove the retaining bolts. You'll notice the pads have a little tension on them. The wholeprocessis rather easy and can be done in about 20 minutes or less.
sportster2007: Do yourself a BIG favor and buy the HD Service Manual. The internet is great for information, but why not get it straight from the horse's mouth? For example, the brake pads are probably held in place by threaded pins that are removed with a 1/4" twelve point socket/wrench. It's much easier to loosen those pins while the caliper is on the bike since those pins are torqued pretty tight. I didn't see that mentioned in the posts reponding to your question.
Also, the pads have an orientation front to back, etc.
It's a simple job with good and complete directions. Get the manual, read it, and come back to ask if there are better procedures, anything not mentioned in the manual, etc. JMHO.
Whenever chaging brake pads on any vehicle, you need to resurface the rotor. During use, pad material is deposited on the rotor. That old pad material can interfer with proper bedding of the new pads. I use 130 grit sand paper disc in a drill motor. Try to create an even shiny surface on both sides of the rotor.
Follow the instructions that come with the pad for proper bedding.
ORIGINAL: fxstcguy98
I have never removed the m/c cover to change brake pads on any car or bike that I have ever worked on. You're just begging for a spill, leak or getting dirt in the fluid. Work smarter, not harder.
