Will 2007 Street Glide wheels fit my Road King?
RE: Will 2007 Street Glide wheels fit my Road King?
Hi, The front should fit fine but your stock rear wheel has a 3/4" axle,the '07 is 1" You'll \\;need to get a set of 3/4" id \\;bearings(JP cycles \\;sells a kit that has both bearings &\\; the spacer that goes inside the hub),you will need a special bearing puller or have a shop do it. You might consider upgrading your swing-arm &\\; axle assembly to the newer \\; 1' 03 &\\; up swingarm. It's a better design &\\; much stronger(the earlier design has been known to crack. I'm sure I saw a couple of posts on this site about doing the change over &\\; you should be able to snag a newer swing arm off E-bay
Thanks for the info. I noticed on the harley parts web that the 2000-2001 had a different part number for the rear. That makes sense now understanding your post. It is a different part number because the axle is smaller.
I'll figure out which way to go.
Thanks again,
EC in NashVegas
Thanks again,
EC in NashVegas
Kbreth
05-06-2019 07:08 AM
