Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Handle Bar Replacement with internal wiring
Old 06-25-2005, 06:46 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default Handle Bar Replacement with internal wiring
Ever try to replace your bars with the internal wiring in them, here's a tip to make your life easier.
Use a vacuum cleaner to pull a piece of string through the bars in the desired side and then use that string as a drag to pull in the wires or another wire that can be used as a drag if you want to pull the bunch through. You may need a bit of lubricant on the wires if it is tight, but be carefull not to chafe the wires going in. It would be wise to chamfer the holes where the wires enter and exit the bars.
Works like a charm and makes your life easier.
St. Bob (12-02-2018)
clap
04-05-2017 08:07 PM
FATKEVIN
10-25-2014 08:33 AM
Keith_71
03-07-2009 02:02 PM
drogers
06-01-2008 06:26 AM
bobbsterkid7
10-12-2007 12:25 PM
Quick Reply: Handle Bar Replacement with internal wiring
