Fuel Moto M8 cam test & dyno charts
H-D Milwaukee-EightŪ 107" Camshaft Shootout
Fuel Moto tested SIX different bolt in camshafts back-to-back to provide an accurate comparison of results. Our test bike was a 2017 Harley-Davidson Road Glide 107" Milwaukee Eight and was equipped with a Screamin' Eagle Stage 1 air cleaner, Jackpot M8 2/1/2 head pipe, S&S MK45 slip on mufflers, and each cam was fully tuned with the Dynojet Power Vision. The following cams were part of this test:
Andrews M460
Cycle-Rama 460
S&S Cycle 475C
Wood Performance-WM8-22X
Zipper's Red Shift 468
Wood Performance WM8-222
The first dyno chart below has all six of the camshafts overlaid to show their respective torque and horsepower relative to this particular set of components. All of the camshafts in our test offered significant performance increases over that of the stock camshaft. We would welcome you to contact one of our technicians at 920-423-3309 Mon-Fri between 9-5 CST to assist in finding the best camshaft to fit your particular riding style.
__________________________________________________ __________________
Andrews M460 Camshaft
Valve Train Noise: Very Quiet
Cam Lope at Idle: Moderate
Description: This cam makes nice broad power. It comes on relatively early and pulls well to the right side of the curve. This cam placed in the middle of the test.
__________________________________________________ ___________________
Cycle Rama CR-460 Camshaft
Description: The Cycle Rama 460 made very good low RPM power (the second best in this test), it also provides a very broad power curve with good upper RPM power.
S&S Cycle 475C Camshaft
Cam Lope at Idle: Very Aggressive
Description: The S&S 475C made the second best peak HP in our test, it accelerates hard. It is very responsive and has the most aggressive lope of all the cams we tested by a significant margin.
Wood WM8-22X Camshaft
Cam Lope at Idle: Aggressive
Description: The WM8-22X camshaft offers the best early torque in this test, and it faired well horsepower wise. This cam is easy to tune and has an aggressive lope.
Zipper's Red Shift 468 Camshaft
Cam Lope at Idle: Semi-Aggressive
Description: The Red Shift 468 placed in the middle of our test for both peak torque and horsepower. It has really broad power, nice and strong through the mid RPM's. It has a semi aggressive lope.
Wood WM8-222 Camshaft
Description: The WM8-222 made the best overall peak horsepower. It made slightly less early torque than the other cams. It has the smoothest curve.
Andrews M460
Cycle-Rama 460
S&S Cycle 475C
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
The following 10 users liked this post by fuelmoto:
Darrin Loecker (02-05-2018),
fordhd2005 (02-05-2018),
johnnynitro (02-05-2018),
MoparBob (02-05-2018),
MTBIG G (02-05-2018),
and 5 others liked this post.
In our second round of Milwaukee 8 cam testing we put the same SIX different bolt in camshafts to the test that were in our H-D Milwaukee Eight 107 cam shootout last month, however for this test we installed them in the Milwaukee Eight 114. Our test bike was a 2018 Harley-Davidson Fat Boy 114" Milwaukee Eight and the bike was equipped with a Fuel Moto AC/DC Stage 1 air cleaner, stock head pipes with non-catalyst slip on mufflers, and each cam was fully tuned with the Dynojet Power Vision. The following cams were part of this test:
- Andrews M460
- Cycle-Rama 460
- S&S Cycle 475C
- Wood Performance-WM8-22X
- Zipper's Red Shift 468
- Wood Performance WM8-222
Description: The M460 cam makes broad power that comes on relatively early and pulls well to the upper RPM's as well. Smooth idle.
Description: The Cycle Rama 460 was strong on both HP and Tq, it has a very broad curve and great mid range characteristics. Excellent response.
Description: The S&S 475C again made the second best peak HP in our testing, however the 114 torque curve was even better than the 107 test. Idle was not as aggressive as in the 107, likely because of the different exhaust orientation. A great candidate for a big bore application.
Description: The WM8-22X camshaft made the most torque overall, this cam drives big torque early on and lots of it. Very strong low-mid RPM response. Strong idle lope.
Description: The Red Shift 468 again placed in the middle of our test for both peak torque and horsepower. It has really broad power, nice and flat through the RPM range. It has great idle lope.
Description: The WM8-222 made the best overall peak horsepower. It made less early-mid torque than the other cams, curve is very broad. This cam likes to rev and is also a great cam to build into for future mods such as a 117 big bore where it really shines.
fuelmoto
Fuel Moto / Jackpot Mufflers
09-03-2010 09:55 AM
