FuelMoto software help!
Had a micro tuner for about a year, but I never messed with the software because it ran great out of the box. Bought some different pipes, requested a new map from FM and received it very fast via email. I also downloaded the software and firmware from their website. The software runs fine, I can get the new map on the software, but I cant get the MicroTuner to connect to the software. In the left corner of the software it says "No Device Connected". Ive tried multiple cords, USB ports, unplugged it all a few times. Tried it with the bike on, off, just the lights on. Also, I know its all connected because when I plug it in, the light on the tuner turns on, even with nothing on, on the bike. Any suggestions? I can call FM on Monday if need be but was hoping to make these pipes my weekends project. Thanks! 2015 Fatboy
For devices like these the USB connection isn't enough - often you need to install a device driver for the operating system to understand that it's not a flash drive even though it's on the USB port - an example of this is TomTom GPS navs.
Was there a device driver to download on their website? (nope, checked - did you grab "Install Micro EFI Tuner Control Center v1.0.0.0"? That's the latest i can find)
Edit, I had a look, it appears that you should have a CD with your device, that has the driver on it (hopefully)
Edit #2 - Plug the usb lead in, then open device manager on your computer (presume windows, not Mac, can't help on Mac) - check if there's a yellow triangle with a ! inside it - that means recognised device but no drivers available.
If you have the CD, tell windows to go to the CD ("update driver", follow the prompts) OR try letting windows "search online" for it.
If you don;t have the CD (or it didn't come with one), search online is all you can do - if you can't find the drivers than it won't work, sorry. (However, someone else might have them and upload them for you, most of these USB driver things are just a "recognition" file to help windows understand what it is that's plugged in)
I had a good google for the drivers but there's too much side-noise in the search results (Micro tuner is also the name of some audio software, I get lots of hits for that and very little for the your tuner)
About the only thing you can do (if the online driver search from device manager fails) is to see if someone here has the cd they can zip up and upload for you - you don;t need the whole CD, just the Drivers folder (or whatever name it has), usually just a few megabytes at most.
TinyUpload is a good host for small stuff.
That's about all I can do, sorry (I can't get all that far without serial numbers and invoice numbers, they check)
Good luck.
Good luck.
It sounds like you may have installed the Dynojet Power Commander V software rather than the FM Micro tuner software. The appropriate software for the FM Micro Tuner can be downloaded from the following link https://www.fuelmotousa.com/files/lp...rol_center.zip
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Question.
I have the same exact problem now. Did you ever find a fix or a software CD?
Pudge211
05-05-2016 09:50 AM
