FXR Models Discuss the FXR Models in here
Swingarm issue
Old Dec 8, 2021 | 05:41 PM
sweatin_dad's Avatar
sweatin_dad
6th Gear
Default Swingarm issue
Hi everyone. First post here. I have a 93 fxr with an odd problem. I have a hard vibration that I think is coming from my swing arm. I had a bearing kit in it before. I suspected that may be the cause of it, so I put delrin bushings in it last week. Today, I rode it about 300 miles. It was ok when I started, but the vibe came back.
it feels like it’s coming from the rear. I can feel it in the seat, pegs, bars - everything. One thing I was particular about was making sure the pin in the swing arm support bracket was centered in the rubber isolator on both sides. Looking at it now, I see that the right side has rotated. It’s not much, but I wonder if that’s enough to cause a problem. Was I supposed to lubricate these parts somehow? The swing arm bushing just slid right in the left side. I could push it in or out by hand. Is that a problem?
one other question - how are the oil lines and rear brake line routed over/under the swingarm? My oil return goes under the trans, over the swing arm and then around the starter. The brake line and reservoir hose run alongside it.
Old Dec 9, 2021 | 07:05 PM
natural gasser's Avatar
natural gasser
"The swing arm bushing just slid right in the left side. I could push it in or out by hand. Is that a problem?"
I believe so. I had to use a press to get mine in. No need to lube anything except I use anti-seize on the pivot shaft. Yeah re-align the support rubber so the pin is oriented, but I don't think that is the source of your vibration. How's your wheel bearings? I've had bad ones cause vibration and high speed wobble.
frustrated72
Shovelhead
Feb 9, 2020 02:01 PM
06Sporty75
Mar 29, 2014 12:34 PM
freakchile13
Jul 1, 2013 06:53 PM
Uncle Scrooge
Jul 16, 2012 04:23 PM
user 37474839
Sep 28, 2007 09:07 AM
