Hard Bags/ Pipes off balance/ different height!
2015 Ultra Limited Low, love the bike and it runs great, I was riding home the other day, with my wife following in truck, after we got home, she said my right side was lower than the left, bag/ pipe! She even took a couple of pictures to show me, one while moving and one while stopped! Sure enough, it looked off balance so I held the bike as perfectly straight as possible while she measured, garage floor to bottom of pipe and floor to bottom of bag! Both measurements reflected a difference of about 7/8" to 1"! She held it up and I measured, same result! No one in all my rides with this bike had ever noticed it, of course I couldn't tell you if any of my friends bikes were off either! Just took it in for an oil change and had HD dealer check it out, at first, they said the mech doing maint. didn't see a difference! Not satisfied, I had someone else look further, two guys thought it was different, he even put a level on the back to make sure I was holding it level. After trying to make some adjustments, he thought he fixed it! I don't think so, still is off a little! What to do, does anyone else have this problem? Bike runs great but the thought of knowing it's off will drive me crazy! Is that asking too much, to be the same height on a $27,000.00 bike!
FWI, I don't see how you can adjust them to fix the issue, all parts involved seem to be FIXED!
Have you checked to see if the support bar is in the bag channel, underneath? Sometimes the mechanics adjust the bags when it's not in the channel....they do that by adjusting the bags where you put the pins in against the frame....or check to see how the bag supports are attached to the frame they can be skewed...
Stock exhaust or aftermarket? If not stock, whoever installed it may have switched brackets left for right. I've heard of this happening to others.
Dan |
Originally Posted by giacomo56
(Post 14476658)
https://cimg1.ibsrv.net/gimg/www.hdf...5b028ad63c.jpg
https://cimg5.ibsrv.net/gimg/www.hdf...d62469e4d1.jpg Ignore the foot pegs, I've adjusted them and they are now level. I'm going straight down the road here and it is quite obvious that the right side pipes, bags and trunk are all lower than the left side. It can't be a pipe issue or a bag issue because the entire right side is lower. The front is level while at the same time the back isn't. Hope this photo shows up. |
From your pictures,the right side muffler is definitely lower.Looks like a trip to the dealer to check other like bikes for this.
From what I see looking at the pictures the whole bike seems to be leaning to the right. Especially the bottom pic, look at the tail lights and rear fender.
Originally Posted by Rick58
(Post 14479756)
That's what it looks like to me too. Bike is leaning slightly. |
Originally Posted by boe1971200
(Post 14477325)
I just realized I have been sitting here for 2 or 3 solid minutes watching your avatar...
© 2024 MH Sub I, LLC dba Internet Brands
