Softail springer lowering?? Need help
Have a 2001 Softail springer. Just purchased rear lowering shocks and new front and rear wheels 16 and 21. Need advice on the best way to do the front end. Just leave stock or lower with springs or rockers. Front end needs service already so trying to do all at once. Any and all tips are a help
Don't have the URL handy, but a company makes a raked kit for the springers to add 4 or 7.5 degrees. Will lower 1 - 1.5 inches.
www.vulcanworks.net for the rake kit or JP cycles has lowering spring kit & tool
Originally Posted by Lapco43FLSTS
(Post 14708550)
Just curious, but why are you lowering a soft tail anyway? For looks or are you that vertically challenged?
Yes slightly vertical challenge. But was lowering rear for looks and comfort. Shocks are adjustable. But wasn't sure how low to go before I start to affect the riding. My main thing is the front. Bc I already have wheel on the way and I need front end serviced because it cannot be packed anymore. So figure while I address the front maybe if the 21 raises the front too much I can lower it. Don't really want to change the rake personally. And lowering springs are last resort I guess. Bc it's a spring so I am assuming smaller spring means bottoming out easier
Like LiiT says leave it alone. if you must use the rockers and not the springs.
Ok just curious. What about rear. Already got the shocks bc was due for upgrade. But it will adjust all threat to -2 inches. How low would u go??
I'd leave it alone, everyone I've ever know with a springer that screwed with the suspension has dropped or wrecked it.
Granted, it's your bike and you can do with it what you want to but from the people that I know around here and from owning one for almost 11 years, just leave it alone.
© 2024 MH Sub I, LLC dba Internet Brands
