SE Heavy Breather question
Hi so i just got a used SE heavy breather from a form member so i was wondering if there is anything I should be aware of when installing it.. it looks like it came with the 2 bolts for the head breather... DO i have to remove the bracket on the throttle body. or its it a straight bolt on.. thanks
Remember this;
With a little searching, you can find the part(s) you have on the Harley web site,, then look at "more info" and find the HD installation instructions.
http://www.harley-davidson.com/store...18-2925308a--1
http://www.harley-davidson.com/app-c...ts/-J05499.PDF
The same is true with many after market parts too, just search the manufacturers web site and do a little digging.
It's a good idea to get new gaskets and O-rings when swapping out an AC.
In this case parts 1-3-7 and 16, They're cheap.
And the bolts do have specific torque values.
