Should I be worried about this tire?
Received 5,388 Likes
Why does it have a crack? How old is the tire?
http://www.tirerack.com/tires/tirete....jsp?techid=11
If the tire is over 6 years old, I would replace it.
Received 1,934 Likes
Drill a hole through the tire at each end of the crack so the crack won't propagate. If that doesn't work, replace the tire.
Just my $0.02
I expect Ron is referring to the date code (year and week) stamped into the side of the tire. You can google up a vid or pic in pretty short order if you're not sure where to look.
https://www.google.ca/imgres?imgurl=...-tDjEQ9QEILTAA
Good that you saw it. Now, it does not look like a cut so the other option is separation. If you ride mostly local then look at it every-time you ride. If you are a freeway rider then have it looked at now...
