Rocker arm support
Rocker arm support
Ok so I've had a really bad ticking sound and I was sure I had a bad lifter. I change the two on the back cylinder then I started to change the front ones and when I took the rocker box cover off the front cylinder I noticed the rocker arm support was broken on the front left side where the rocker arm pin goes through the support. Does anyone know if these are expensive if i get through the dealer? Not sure I would trust getting one of e Bay or some place like that.
Halesbells (07-24-2016)
Here's a really handy link Hales,, the actual microfiche files that the parts guy at a dealership looks at,, and it includes prices.
Just enter your year and find your model,, there is a small learning curve looking though the stuff but you'll figure it out. You should bookmark this link;
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
It's handy to go to the dealer parts guy with the actual part number you need.
As mentioned, the support plates are surprisingly cheap.... about $32.50 online. (Assuming twin cam). The shafts are just $8.50 each, you'd do well to replace them too.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
skjskmata
Engine Mechanical Topics
11-11-2011 12:06 AM
skjskmata
11-10-2011 11:52 PM
