Drive belt noise
Drive belt noise
2001 Road Glide. Seems like the rear drive belt makes noise, but only after it's warmed up. Belt tension is set at 3/8" or a tad more, the wheel is lined up in the swingarm per service manual with a guide rod and taking measurements off of the main swing arm pivot bolt. Anyone else have this problem before and if so what is the cure ?
Thanks in advance Jonnierock
Received 5,388 Likes
Adjust it with a gage. Be sure you are using correct service manual since they are different as to if seat is loaded or not. Hit a few sprays of talcum power on it. It will lubricate it and if that is noise, it will go away. New belts come with something on them. It wears off pretty quick but then dust usually takes over. Some keep things so clean, rubber belt squeaks. (do not breath power..it's a hazards nowdays)
