Grip Ace electrical
Grip Ace electrical
Anyone running a Grip Ace? Since day one, when I for instance hit a blinker button, sometimes it needs a double tap. When I switched to a Daymaker it got worse. It seems to me that it is a resistance issue, so I want to add a resistor in line on a headlight wire. Just wondering what value I would use or how to confirm value other than testing out a bunch of resistors.
if since day 1,you should have contacted Tim at GripAve. He's help you out.
I have a Daymaker as well with no issues in 06 Night Train.
My Gripace came with a fuse or something of the sort if needed. Never used it personally.
BUT; I do have issues with my pad or module at the moment. Either the 2 start buttoms take a long time or don't even function at all. Right blinker sometimes activates the hi/lo beam....which is the very left button on the grip. Something is off.
Need to send the module in for testing according to Tim @ Gripace.
old thread, but...
still subscribed. Lol. Mine does that also. I'm convinced it's a resistance issue. I put stock bulb back in and it's a lot better with signal lights but not perfect. That says a lot. I'm gonna get a resistor thrown in as soon as I have some time. I am not tearing put the module. It's buried under the tank. Maybe this winter but we will see. I emailed them with the signal light issue last year and never got a reply.
