Brake Light issues
Old Sep 26, 2016 | 06:14 PM
Joshus41's Avatar
Joshus41
Default Brake Light issues
I have a 2011 Crossbone and my brake light stopped working and I got a red light on the right side of my speedometer on. The rear lights is still on but, neither the hand brake or foot brake activate the brake light. Tried an original brake light module and a bright *** brake module, with the same results.
Before I trailer it to the dealership, what else could cause such an issue?
Old Sep 26, 2016 | 06:21 PM
dickey's Avatar
dickey
Since both are out, I would check the brake light fuse, and ALSO the cruise control fuse, since in some cars & bikes the 2 are on the same circuit.
Might be a dumb question but...did you check to see if the brake filament of the bulb was burnt out?
Old Sep 26, 2016 | 08:31 PM
skratch's Avatar
skratch
also, check to see if the brake light is on all the time. if so, then you've got a switch issue. did you change anything lately? handlebars? grips?
Old Sep 26, 2016 | 11:31 PM
gusotto's Avatar
gusotto
I have a Brightass taillight.
Love it but you can't just take from an older bike and put it on a newer bike.
Sold some for a friend but called Brightass first.
Have to watch the SN.
Newer bikes need a certain SN and up to work.
Old Sep 27, 2016 | 02:41 AM
JustOneDean's Avatar
JustOneDean
If that red light's on, the bike's throwing a code that can at least give you a starting point. With the ignition switch off, hold down the trip button, then turn the ignition switch on while still holding down the button. Your gauges should do a full sweep, and then you can use the trip button to cycle through codes on the odometer.
Briguy1
Electrical/Lighting/Alarm
Feb 9, 2015 06:10 PM
sorensentyler
Aug 4, 2014 08:24 PM
AZCHOKESTER
Jan 10, 2008 10:34 PM
Skip
Aug 12, 2006 01:48 PM
KenM
Jul 3, 2006 03:23 PM
