Cam Chain Tensioners 03 hd
JYI, I recently got the HD, bs treatment from my local HD dealer, they said I had to change my chain tensioners on my 03 Fatboy, had 42k miles recommended at 25k, well I did even though I'd been told by several others that I probably didn't need to do this. Turns out they were correct, mine had less than .030 wear on them, so if you always use 100% synthetic oil (mobil 1, amsoil), you might want to inspect them first, (which is what I should have done) and one more thing the hydraulic system is not better than the original system more bs from HD, HD should factory recall this pos and fix the pos if it's that bad. Since then I've seen two others changed out 58k and 81k, they were worn a little more, but not much, about .060-58k and .070-81k, both still had plenty of life left, so I strongly suggest inspection before replacement.
The following 3 users liked this post by Hasher:
