Resetting trouble codes (DTC's)
I have a 2002 Road King that has several trouble codes set. I have since fixed the problem but need to clear the trouble codes.
' The procedure is different for later models (2003 and up). Searches does not show method on how to clear the DTC's for the 2002 and earlier only how to retrieve them nor does the Electrical Diagnostics manual tell how to do this. ' Anyone know how to clear the codes? I would like to clear them so I can tell if they are reoccurring or not. I understand they will clear after a set number of start/stop's of the engine, I heard 50 start/stops, but that is a long time in coming. |
Originally Posted by Rustyg500
(Post 15666923)
' The procedure is different for later models (2003 and up). Searches does not show method on how to clear the DTC's for the 2002 and earlier only how to retrieve them nor does the Electrical Diagnostics manual tell how to do this. ' Anyone know how to clear the codes? I would like to clear them so I can tell if they are reoccurring or not. I understand they will clear after a set number of start/stop's of the engine, I heard 50 start/stops, but that is a long time in coming. A “trip” consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diagnostics manual you're not going to know what they mean. |
Originally Posted by MikerR1
(Post 15667154)
I do not know if this will help you. It shows how to display the trouble codes for 00-03 Road Kings. Read the Important Note, because in there it says that the trouble code will stay in memory until cleared by a Scanalyzer or 50 trips have elapsed. A "trip" is defined,in the quote below, as a start and run cycle lasting at least 30 seconds.
https://www.hdforums.com/forum/touri...ml#post8767805 |
(Post 15668596)
Thanks Mike. That is what I feared. 50 cycles does no good if you are having intermittent issues and I do not have a Scanalizer. With the code staying there for 50 cycles then you do not know if the code being displayed is recent or residual so you have no idea if you have fixed the problem.
The new version of the tool is called TwinScan II abs. It sells for $400. But you do not need that version. You need the older version, Twin Scan II (not abs). I do not see it listed on their website. I have the Twin Scan II but I cannot use it anymore because I have a 2016 bike and it will not work on my new bike. I recommend you call Daytona Twin Tec and talk with Alan Alverez. He is the owner and possibly the nicest owner of a big company that you will ever talk to. Tell him you have a 2002 Road King and you need to view and clear trouble codes. Maybe he has one of the older units sitting around the shop. Here is the phone number 386-304-0700. You might consider getting one of these because you now know you may need it in the future. Daytona TwinTec is a great company and they make good products and they are extremely easy to talk to. NOTE: He says in the video it is for 2001 - 2011 Softails. But I know for a fact they work for the dynas, because mine worked on the 2004 wideglide. If you call him make sure you tell him you have a 2002 Road King. |
(Post 15668783)
Here is a link to a short video for the Daytona TwinTec Scan II tool. This tool will allow you to view and clear the trouble codes on your bike.
The new version of the tool is called TwinScan II abs. It sells for $400. But you do not need that version. You need the older version, Twin Scan II (not abs). I do not see it listed on their website. I have the Twin Scan II but I cannot use it anymore because I have a 2016 bike and it will not work on my new bike. https://www.youtube.com/watch?v=TuekJniNEyU I recommend you call Daytona Twin Tec and talk with Alan Alverez. He is the owner and possibly the nicest owner of a big company that you will ever talk to. Tell him you have a 2002 Road King and you need to view and clear trouble codes. Maybe he has one of the older units sitting around the shop. Here is the phone number 386-304-0700. You might consider getting one of these because you now know you may need it in the future. Daytona TwinTec is a great company and they make good products and they are extremely easy to talk to. NOTE: He says in the video it is for 2001 - 2011 Softails. But I know for a fact they work for the dynas, because mine worked on the 2004 wideglide. If you call him make sure you tell him you have a 2002 Road King. |
Originally Posted by deadman77
(Post 15668876)
Dont take this the wrong way but were you able to get your own bike fixed?
(Post 15668911)
What do you mean? My bike is not broken. The only thing that does not work on my bike is my stock gas gauge and I have no intention, as of now, to have it fixed. The Range option (how many miles I have left in the tank) does work. Since the range option works off of the float in the tank (as the gauge does) I am not going to worry about the gas gauge. Maybe 2 years from now I will have it fixed under warranty.
You have much advice to offer but cant seem to get your own to the proper techs to get it figured out. |
(Post 15668929)
I am asking about the 5 day wont run on Saturday or Sunday issue.
You have much advice to offer but cant seem to get your own to the proper techs to get it figured out. Also, I did not say it won't run on Sat and Sun. I said that if I let it sit for 5 days it does not run good on Saturday, but, it does run good on Sunday. |
Nuff said from me. There is a simple solution.
Take that statement the way you want to. In before the lock. |
(Post 15668942)
Take that statement the way you want it. |
© 2024 MH Sub I, LLC dba Internet Brands
