Knuckle warmers
Knuckle warmers
Hello,
Riding around this past year another rider made a comment about keeping his hands out of the wind while riding with ape hangers. Since I like the ride with 14" apes I was hoping for the same thing. Was about to buy a pair from another forum member, they were sold before I was able to. Did some research on them. Most of the hand guards that I saw were held by the mirror stud, which I thought was a pita. Kept researching til I found these. They are easily installed and easy to remove with out bolting them down. Went on a ride yesterday and they do help keep the cold and rain from your hands. Here is a link for anybody else interested.
http://knucklewarmers.com/
I've used hand "wind deflectors" on my bikes for over a decade.
They give you added protection from the wind, rain and even gravel, but if it's cold out (consider "wind chill" too) you really need insulated gloves or better still, heated gloves.
I've been riding since '69 and I cannot believe that I went this long without "heat"!
I now have a heated seat, heated grips (great for cool weather) heated jacket liner and heated gloves, but overall I think the greatest return for the investment is the heated gloves.
Just curious, how do you guys keep your armpits warm?
I wanted to get these so when it's cold in am I can put these on without having to wear a bulky glove. When it's warm enough I can take them off, just like soft lowers. I agree when it is down right cold I will and do wear my heated gloves. The product is easy and fast to take off or put back on. That's my whole point. The ease of it while obtaining the comfort.
Received 8,231 Likes
I bought a pair of what I called elephant ears from local dirt bike shop. They were foam/fabric and mounted via Velcro straps. I believe Moose made these. $20 I believe was cost. On and off in seconds. Did nothing more than block the wind, which helped in cold weather. Looks goofy, but did what they were intended to.
Hello,
A couple buddies use these from street HDs to hunting RVs.
http://www.ebay.com/itm/2x-Winter-Wa...-/371394680885
I have a pair of these, for $13 I had to try 'em.
http://www.banggood.com/Waterproof-M...-p-969942.html
I've used them on a couple 35 degree mornings, when I wouldn't be able to ride otherwise. They do look goofy, and it's a little challenging finding turn signal/horn buttons. I also don't pull my hand out of them because slipping a gloved hand back in takes more effort than just grabbing the bar.
I'll probably get heated gloves next year.
aecs (11-22-2016)
Back in the early 90's my bike was my sole source of transportation even in the winter.
2 50ohm 10 watt resistors in parallel mounted on home made stand off brackets (10 gauge solid core copper ground wire lefty over from my base station antenna) under a pair of hippo hands.
Current draw is .55 amps at 13.8 volts with a total of 7.6 watts, (3.8 watts per resistor) of heat generated
15 degrees at 3:30 in the morning going home from work wearing nothing but cotton jersey gloves.
Last cold weather tour I went on I used 'Aerostich Triple Digit Covers' over my regular cold weather gloves and that worked fine down to about 30 degrees. Before that I had a pair of elephant-ears (Bark Busters / Bush whackers / etc.) that cut down the windchill and extended my riding down to 15 degrees.
After trying everything under the sun I consider heated grips to be essential. The older I get the less my hands seem to heat themselves.
