how to clean injectors?
I have a 08 ultra with 50,000 miles. just did fuel pump wires plugs oil etc. is there a way to clean the fuel injectors ? I have hooked up a can to my truck to clean the injectors. But how do you clean on a harley ? any tricks ? or just add something to fuel? if adding to fuel what should i use that really works ? any experience ?
Berryman b-12 chemtool for the injectors
Seafoam to clean carbon out of the pistons Don't add then simultaneously Ghost |
If you've never cleaned the throttle body, do it also. Just remove the air cleaner, wet down a good lint free shop towel with some Seafoam and wipe it all out real good. Front and back of the butterfly too. Makes a big difference in idle smoothness and response.
© 2024 MH Sub I, LLC dba Internet Brands
