Question for those who have S&S gear drive cams
I have 103 with 25,000 miles and was concerned about the hydraulic chain tensioner on the cam. Harley can't tell me when it should be checked, only when I bring it in for service (Ya, like that's going to happen) they would do it as part of the maintenance. Is it worth the expense to change the chain drive to the gear drive? More so of the extended reliability of the cams, than the cost. Hate to get out some where and have that shoe go. Or is the tensioner reliable? How many miles is the average life of the tensioners? (Why Harley could't use a gear tensioner or even over head cams, I can't understand).
If you have a 103, you have the later style hydrolic tensioners that are fairly trouble free. With 25k, I wouldn't worry about them. Popping the cam cover off to check them is pretty simple. With gear drives, you'll have to worry more about crank runout than anything else. If you want OH cams, there are plenty of metrics to choose from.
Quiet Thunder (11-27-2016)
The tensioners will account for runout. With chain drive, no gears are touching each other. With gear drives, and bad runout the gears are either separated or mashed together; neither being good. The runout issue is with the crankshaft.
The following 2 users liked this post by bill from tn:
Keithhu (11-27-2016),
The following 2 users liked this post by Next In Line:
Quiet Thunder (11-27-2016),
Rickity (09-25-2017)
joe v
04-10-2006 02:40 PM
