bike wont start just clicks
http://tinypic.com/player.php?v=nga4q0&s=9
here's a short video of symptoms
things iv'e tried:
replace battery about 7 months ago thought it was that
checked all connections
took our spark plugs has good compression , not frozen piston
tried to jump it still clicks
out of ideas any suggestions?
things iv'e tried:
You have a connection problem. As stated above, check for ground(s) clean all connections.
When it clicks did you check for voltage on both sides of solenoid, is power getting to starter if so how much (voltage meter).
One click per starter button push is power to solenoid, need to see if it is reaching the starter.
Moss code indicate poor ground or bad connection.
