Stumble at 2000 rpm
Stumble at 2000 rpm
2008 ULTRA 52,000 MILES. bike has rough idle and a stumble at 2000-2200 rpm. the complete fuel pump assembly , plugs, plug wires were all changed about 1000 miles ago . ran sea foam for the last 3 tanks but no change ! Above 2000 it runs great ! any ideas ? things to check? throttle body is clean and i put oil breather from the air cleaner and put under the bike . fuel injectors , intake leak, fuel management , a sensor? I have always done my own repairs , I do not want to take to dealer but if i cannot figure out what is wrong i will have no choice . any ideas or similar problems ? any help would be great !! THANKS
Idle issue resolved today
Today I replaced plugs, mi. on exist. unknown but they didn't look bad, front was a little darker. Replaced batt., inspect and clean conn's and ground. Pulled K&N air cleaner, inspect and clean (wasn't dirty, only 1K mi.)
Clean intake and IAC, check operation, pull TPS conn., clean, inspect and reconnect.
Started right up, sounded great, took a short run around hood (raining too much for a ride) ran great, smooth idle and good power on take off.
Just like a woman, just needed a little hands on attention to purrrrr like a kitten. Or should I say rumbbbbble.
