09 Road King cranks no spark
what do you mean by "won't turn over"? won't crank? Won't start? Does it have a security system? How did you check for spark, if it won't turn over? Did you accidently leave a wire off, when you did the battery? Assume you can hear the fuel pump charge, when you turn the key on? Need more info to steer you in a direction.
How about:
Starter (doesn't) turn crankshaft.
Engine (doesn't) start.
Sorry had to go underway but got home and replaced the ignition coil and started right up. Let it run for a while here no problems. Took it out for a ride about 25 miles just to test out and again no problems. Seems to have fixed the problem. Thank you so much for the help here. I really appreciate it!!
tar_snake (07-24-2017)
MikeyRelentless
11-13-2012 08:10 AM
