How to tell if you have ABS
JediGoalie30 (05-03-2017)
Received 4,353 Likes
Received 1,934 Likes
Campy Roadie (05-03-2017)
These pictures are from a 2011 Street Glide, but you will still have that ABS sensor wire if you have the ABS option.
This shows the ABS sensor wire next to the brake line.
hairymoth (05-10-2017)
Do what the prior posts suggest;
OR if that is too boring for you
Go really really, really, fast and ride into a 100+ yard patch of loose sand, wet leaves, ice, banana peels, or what have you, then hit both brakes as hard as you can, while pulling in the clutch so you don't stall the engine. If you don't have abs you'll likely lock up both wheels, wipe out and slide till you run out of inerita.
junior07 (05-03-2017)
