What did everyone else do?
Hi,
I was just wondering. I just traded in my bike that had a tourpak which is where I mounted my gated communities barcode for easy community member access. I no longer have a large flat surface to mount a barcode sticker on and my community requires a "permanent" mount. Anyone here ever find or use a mount of that sort?
Do they have any requirements other than being permanent? Does it have to be located in plain view? I've seen a couple different products that are semi-permanent, normally used for mounting vehicle inspection stickers if the owner doesnt want to stick it on the frame. There's a lot of them out there I think, possible to mount in different locations.
http://www.jpcycles.com/product/7010040
Hmmmmm!
In my case it's gated to keep all the rif-raf IN!
The bar code sticker has to be permanently adhered to a surface on the bike. I was thinking that a small piece of Lucite attached to the right side rear view mirror somehow would work. These are normally stuck on the side of a car, most likely rear window, where the bar code scanner (window height) can read it. Somebody out there has purchased or made this mod. It's just a matter of finding him/her!
Received 5,374 Likes
