Broken bolt! Fuel tank canopy
So I just changed the fuel filter on a crossbones and while tightning down one of the bolts, the damn bolt head snaps clean off, hadn't even torqued it down yet. It was a new bolt.
What are my options? I thought about just leaving it and worry about it next time. The diameter is to narrow to use a bolt extractor, to deep to weld anything on it, at least I think it is.
Worst case scenario I'll get a new (bran used) tank and fuel system next time I have to get into the gas tank so its not so bad I guess.
Received 47,780 Likes
You really wanna get that off and use a good bolt. If that canopy isn't tightened down evenly, you could get gas leaking out. Left hand drill would be the best idea, or take the canopy off again and see if theres enough bolt left to grab. Might run a tap through the hole once it's clear to make sure the threads aren't damaged.
Use this. Home Depot and Lowes sells a similar product. Speed Outs or something like that.
https://www.grainger.com/product/1U2...170512194647:s
Here's the Home Depot version.
http://www.homedepot.com/p/Ontel-Spe...Q&gclsrc=aw.ds
